barebone system for testing
Discussion in 'New Build / Upgrade Advice' started by jester45, Aug 25, 2006.
  1. jester45
    jester45 Big Geek wanna be
    i have intill the 31 of this month to get a barebone system for free but i want to to be cheap becuase i will probly pay it back but i was thinking about this here
    but im not sure if it comes with ram cpu becuase of the list on the upper right corner
    if anyone could help becuase even if its cheap i dont to get it then have to go get stuff for it
    or do u have any other ideas i need it to be a cheap as possible there are my own reasons for it to be cheap becuase i might hurt it beond repair me and my friend are going to experiment with it diffrent linuxes how many viruses we and get on it and other things u would never what to do
  2. donkey42
    donkey42 plank
    i also noticed that it's got integrated grfx - not good
    and it's only got a 275W PSU, not many modern PC's will work with less than a decent make 400W PSU or more
  3. Matt555
    Matt555 iMod
    Those barebones systems are often just a case, a PSU and a motherboard - in this case it's a Socket 754 Motherboard - they're old and CPU's aren't produced for that socket anymore.
  4. donkey42
    donkey42 plank
    Edit: that's what "barebone" means - no CPU, RAM and grafx
  5. jester45
    ok i did a few more hours of searching and found these
    this is the barebone system
    Page Computers
    cpu
    Intel Celeron D 351 3.20GHz 256KB Cache 533MHz FSB OEM Socket 775 Processor HH80547RE088CN at TigerDirect.com
    ram(i will upgrade to 2g later)
    DDR DIMM Memory, 184-pin DDR DIMM Memory, DIMM Memory, Computer Memory DIMM, Memory DIMM 184
    if u guys can tell me if the mobo will suport that cpu because at the barebone site they say intel p4 but the celeron is cheaper and has the same bus and socket??
    i will searcher later into the cpu/mobo compaiblty
  6. izzy007
    izzy007 Big Geek
    .yeh celeron is cheaper but it is shite compared to the p4.u cant really play games on it or intensive task, only internet browsing and office applications really. i wud reccommend at least a p4
  7. Matt555
    Matt555 iMod
    Celerons are P4's with their 'wings clipped' so to speak.
    They have lower FSB's and less L2 cache - often they're CPU's which were intended for P4 use but had damaged parts of the cache - they're sold as Celerons as they can shut off the damaged cache and use only the good cache.
  8. jester45
    the p4 cost alot more that celeron is like 60 usd and the cheapest p4 was 119
    but the celeron will work on that mobo right?
    o and i just thought of this my sister just got a new computer and it has xp on it, if it has a recovery disk could i use that to install xp on the new system
  9. Matt555
    Matt555 iMod
    Well that would mean using 1 XP licence for 2 computers and that's not allowed for standard liscences. You'd have to buy your own XP licence.
  10. jester45
    well would it install and not beable to use the auto updater or just no install
    if the installing xp will not work i will just try linux but linux isnt realy that good for gameing
  11. Matt555
    Matt555 iMod
    What you're wanting to do is illegal and we do not condone it on this forum. I'm afraid I'm not going to discuss that any further.
  12. jester45
    ok no problem i cant and dont want to force you
  13. jester45
    so your sure that the celeron will work i might get a p4 later or maybe a core2 extream if the celeron isnt that bad
