bios problem
Discussion in 'CPU, Motherboards and Memory' started by Kozok, Nov 29, 2010.
  1. Kozok
    Kozok Geek Trainee
    When I boot it stops at Verifying Data Pool and also it says smbus cntrlr NA. I've tested my memory, and multiple hard drives. I'm pretty sure it has been narrowed down to a BIOS problem. Any help would be much appreciated.
  2. Kozok
    Kozok Geek Trainee
    My specs are:
    o GIGABYTE GA-MA785G-UD3H AM3/AM2+/AM2 AMD 785G HDMI ATX AMD Motherboard
    o 1 x Rosewill RP600V2-S-SL 600W ATX12V v2.01 SLI Ready Power Supply
    o AMD Athlon II X2 240 Regor 2.8GHz Socket AM3 65W Dual-Core Processor ADX240OCGQBOX
    o G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-2GBNQ
    o 1 x Western Digital Caviar Green WD7500AADS 750GB SATA 3.0Gb/s 3.5" Hard Drive -Bare Drive
  3. Wildcard
    Wildcard Big Geek
    Hi,
    If you think the BIOS is causing the error, try resetting the BIOS to its defaults to see if that helps. You can either go into the BIOS to do this, or you can unplug the computer and take out the coin battery and then hold down the power button to discharge the system board for maybe 20-30 seconds. That should reset it. If that doesnt help, you can go to the BIOS manufacturer's website to see if they have an update for your BIOS that you can install. They should have the instructions on how to do this on the website.
  4. Kozok
    Kozok Geek Trainee
    I have already flashed the bios. And I cannot boot the os so I am limited in what I can do.
  5. Kozok
    Kozok Geek Trainee
    I finally got the computer to boot with CD and am trying to repair but it says it cannot copy hidserv.inf. Is there a way to fix that or should I just hit skip and hope it works?
  6. Wildcard
    Wildcard Big Geek
    That is a file that allows for the use of shortcut buttons on usb keyboards according to microsoft. As long as that is the only file that doesnt copy over, I think you should be ok. If you start seeing a lot of files not being able to be copied, it may be that your CD has some bad sectors or the HD where it is trying to copy to has some bad sectors.
