building a quiet pc
Discussion in 'Cases, Modding and Gallery' started by efx2003, Jan 29, 2005.
  1. efx2003
    efx2003 Big Geek
    Does anybody know of any web sites that are safe to buy quiet pc parts. Please help if you can.
    Thank You
  2. Big B
  3. efx2003
    efx2003 Big Geek
    Thanks for the help. Buddy
  4. matttibb
    matttibb Geek Trainee
    My pc is weird, it gets a really annoying buzzing noise if I leave it on for a few hours but stops if i just move it slightly. :confused:
  5. Addis
    Addis The King
    Thats usually because of the fans/drives vibrating and causing the case to vibrate also.
  6. matttibb
    Oh right
  7. ProcalX
    ProcalX all grown up
    This is a subject that is very close to my heart - quiet cooling..
    My pc runs stock at:
    CPU: 31-32C (idle) 39C(load)
    System: 24-25C
    PWM: 28C
    And i am running:
    2x 80mm Vantec Stealth Fans @ 21DB
    480W ThermalTake Silent Purepower (fan controlled - on low setting)
    Akasa Acoustic Matting (surrounds the edges of my case fans, harddrives and cdroms to stop vibration and is on the bottom of my case, and all side panels)
    Artic Freezer 64 HSF @ 16-21DB
    My case is literally inaudiable.. its almost completely silent, when i say almost the only thing making any audiable noise.. is my graphics card (6600GT) which has a rather loud HSF on it (retail). Just waiting for Artic Cooling to bring out a silent HSF thats compatible :)
    Get a case thats good quality = reasonable weight, this means that it wont be flimsy, as if it's flimsy you will get ALOT of vibration.
    Which ever case you get it will most likely have "grills" at the back and front of the case to basically protect people from shoving their fingers in the fans..
    If you think its safe, ie no small children e.t.c cut these grills out, it looks unneat.. well mine does anyway, (i've done it at the back of my case) with a simple wire cutter, it will lower the db of noise the fan is making, as there are no metal grills in the way blocking the air flow..
    Wiring is another thing, try when you build you computer to make sure that your powersupply connection (20ATX and 4ATX cable are not situated above the HSF, as this will partially block airflow out of the case.
    As for other wiring, such as IDE cables / Case (front panel) wiring, try to hide it in the side panels, behind the IDE compartments or under the motherboard, it can take a good few hours to get it right but it is worth it :)
    If your using IDE cables buy some Akasa Rounded cables, these are as you may have guessed.. Rounded IDE cables, which are quite small and very neat, they make the system look alot better and provide much better airflow.
    Hope this helps :)
  8. efx2003
    efx2003 Big Geek
    What web site can I get noise proof foam. Thanks for the help buddy
  9. extreme4377
    extreme4377 Big Geek
    Just to add to Procals post, Nexus Damptek available from silentpc.com or endpcnoise.com, both very reputable resellers, is the best sound absorbtion material available. Nexus fans from endpcnoise.com are the best for silence/airflow. Vantec stealths really arent, well, stealthy. Theyre louder than most other brands, Panaflow, Nexus, etc.
    Cutting out fan grills helps not only temperatures but noise levels too. The grills just slow down air and create turbulence. Check out the fan isolators available on endpcnoise.com for mounting your fans.
    You should also consider suspending your hdd.
    For more info, check out www.silentpcreview.com and their forums too
  10. efx2003
    efx2003 Big Geek
    Thank you very much I will try those web sites.
