Computer problem
Discussion in 'General Hardware' started by ranjith2523, Aug 31, 2010.
  1. ranjith2523
    ranjith2523 Geek Trainee
    Hi,
    I have 3 years old computer... suddenly it stops working
    symptoms
    Power on
    Cpu Fan running with constant speed
    Smps Fan running with constant speed
    Cabinet Green Led Wont Powers Up
    Cabinet Red Led Wont Powers Up
    No display in Monitor.
    Action taken
    Bios cleared by removing battery and jumper
    Working smps changed but same symptoms remains.
    Please let me know if u know any tricks to make it work.
    Many thanks in advance.
    Ranjith
  2. HardwareHunter
    HardwareHunter Geek Trainee
    Is this a laptop or desktop? Try plugging in a different monitor to eliminate monitor issues.
    Also try a power drain to remove the electrostatic energy. If it's a laptop, remove the power adapter. Take the battery off. Hold down the power button for 30 secs, then put the battery back in.
    Let me know if this works.
  3. daz
    daz Geek
    It looks to my like you motherboard failed. try to disconnect all the extension cards, drivers and power on only with one memory stick and CPU. See what happens then.
