Could a memory upgrade be causing a problem in my laptop?
Discussion in 'CPU, Motherboards and Memory' started by Girevik, Dec 1, 2008.
  1. Girevik
    Girevik Geek Trainee
    I have a Toshiba Satellite laptop and upgraded the memory this weekend. I've not had time to do a lot of playing around with it, but it seems that at least sometimes when I start it up it just seems to not do anything. The power light comes on, but not much else happens. If I hold down power to shut it off and then turn it back on it seems to work (at least so far), but I've had this happen more than once. I've also tried shutting down and restarting right away to test once and that worked fine.
    Does anyone have any clue as to what could be going on here? If it is the memory, is there a reason why it would work when I shut it down and restart?
