Cpu temps question
Discussion in 'CPU, Motherboards and Memory' started by MarioNik, Nov 26, 2013.
  1. MarioNik
    MarioNik Geek Trainee
    I have an intel i7 920 and the temps are 35-40 idle ,at full load 60-65.I have a water cooler coolit alc 240mm but i worry if the temps are fine or not.I have re applied thermal paste but the temps are the same.Please help if you know more on this.
  2. Ghostman 1
    Ghostman 1 Mega Geek
    There is nothing wrong with those temps,You don't need water cooling... what case are you running?
  3. MarioNik
    Ok if you say so.My case is coolermaster haf 922. :rolleyes:
  4. Ghostman 1
    Thats a nice case, It should be more than enough for cooling.. It looks like it has 4 or 5 fans..
