CPU voltage issue
Discussion in 'CPU, Motherboards and Memory' started by Darcadian V1, Oct 7, 2007.
  1. Darcadian V1
    Darcadian V1 Big Geek
    Just got my new system up and running and sifted through the usuall wierd stuff that happens. Theres still one issue concerning me though. The systems is running perfectly stable it seems but just now I loaded up the ASUS PC PROBE II utility and it give a warning on one of the voltages. All other voltages are solid but "CPU - NB HT" voltage is reading over 10% higher than it should be.
    Should I be concerned about this?
    SYSTEM SPECS:
    CPU: AMD Athlon 64 X2 6000+
    MOBO: Asus Crosshair
    MEMORY: 2GB Crucial Ballistix DDR2 PC2-6400C4 800mhz
    HDD: x2 80gb Western digital sata II drives
    PSU: Antec Truepower Quattro 850W
    GPU: Sapphire ATi Radeon HD 2900 XT
    Thanks in advance.:good:
