Hey, I recently switched back to my utrdx200 because my other mobo fried, and things are working well, except for the fact that I have no idea where to put the Pwr Swtch cable from inside the case. I need to be able to turn my computer on from the button on the case and there appears to be no spot for it on the motherboard, hd led, power led, reset switch, and speaker are all labeled and working fine. any ideas from someone familiar with this? thanks a bunch
My first guess would be to peek into the manual of your motherboard. Those usually describe in quite a detail, which pin on the board has which function exactly. I think that you should be able to attach the pwr swtch cable easily to the motherboard (I mean - finding it will be easy, connecting it to the mobo will be a different story - that has caused some pain for me in the past, cause those pins are so damn tiny)
I've read the entire thing with no luck, they dont even mention it, just the other switches i talked about
I know when I got my NF4 Ultra-D, the manual included was a little short on details. I did check DFI's website and found the manual in a PDF format here. Go to page 69 for the front panel connectors. I looked at the labeling, and I can see where some confusion is. The power button pins seem to be labeled as "ATX-SW", and not PWR or PWR-ON as I've seen on other motherboards.
