We are using one assembled PC with Asus P8H61MLE motherboard & 2GB DDR3- 1333Mhz Zeon Ram We are facing display problem problem in this PC. When we re place the Same same again to the same slot the display will work for few days. And again we need to repeat the same method to get the display after few days. What will be the problem?
What video card are you using?Are you testing with one stick of ram or two ? Most display problems are either Video card or Monitor..
Thank you for your suggession. There is onboard display only and we are using only one memory stick that is 2GB DDR3
