e8400 stock voltages and no OC, too hot?
Discussion in 'CPU, Motherboards and Memory' started by gabb, Nov 25, 2009.
  1. gabb
    gabb Geek Trainee
    Hi guys.. I have an e8400, no OC.
    Artic Freezer 7 Pro HSF
    Idle temps are about 49C and full load or when gaming about 72C
    My CPU is C0 stepping. Maybe the sensors are bad..
    I applied the arctic silver just fine (not the first cpu I installed) and heatsink is mounted correctly.
    Is my stepping just bad or is something wrong? When gaming or running Prime95, I never get errors or crashes.
    Here are some screenshots of Realtemp and a prime95 test. As you can see.. temps went up to 77C.
    Are the Tjmax distances OK?
    Thanks guys
