first build - will this work? (any advice?)
Discussion in 'New Build / Upgrade Advice' started by accessgranted, Sep 28, 2011.
  1. accessgranted
    accessgranted Geek Trainee
    Item Unit Price
    Intel Core i7-2600K 3.4Ghz 1155pin Boxed CPU $325.0
    Gigabyte GA-Z68XP-UD4 DDR3 Intel 1155pin Motherboard $212.0
    Kingston DDR3 1600 HyperX Blue 4GB Kit(2Gx2) CL9 $44.0
    WD 3.5" Green 2TB WD20EARX SATA3 HDD $83.0
    Lite-On SATA DVD RW - 1 Year Warranty $24.0
    Coolermaster Extreme Power Plus RS-700 Watt. PSU $87.0
    AeroCool Black Hawk Top Docking Front Hotswap $115.0
    Microsoft MS Windows 7 Pro 64bit OEM $127.0
    Total - $1017.0
  2. M_Kincy
    M_Kincy Geek
    it will work. i would recomend not getting a green HD
  3. petersmileyface
    petersmileyface Geek Trainee
    Just to add to M_Kincy, you should get either a Caviar Blue or a Caviar Black (both from WD of course).
