Front Panel Connectors
Discussion in 'CPU, Motherboards and Memory' started by NN510, Oct 8, 2015.
  1. NN510
    NN510 Geek Trainee
    I recently started my first computer build and need some guidance.
    I'm using an NXZT H440 case and a MSI Z170 motherboard. I'm attempting to connect the front panel connectors as described in the mobo guide, but am not quite sure I'm doing everything right. As far as I can tell I have everything going where its suppoused to be going, but no matter which way I turn the wire I can't get the connector to 'click' into the motherboard. Are they just supposed to be loose against it?
    Here's a picture of my wires in front of the area where I'm supposed to put them
  2. Big B
    Yeah, the front panel connectors don't click in place like you might find on SATA connectors. Some motherboards come with a jumper block to make it easier, but outside of that, the connectors haven't changed in over 20 years.
