Hey, I recently bought the Asus A7N8X Deluxe MB and installed it in an ATX with two front panel USB ports. There are three, single jumper connections for each port (power, ground, something else), but I don't know where to put them on the board (the manual isn't that helpful). Anyone have the same problem? Thanks
Nevermind, I got it For anyone having the same problem, there's a set of 9 jumpers on the board labelled USB34 (or 56). Put power jumpers on far left ones, the minuses after that, then pluses, then grounds. (one port on top, one of bottom)
