gamepad help crisis
Discussion in 'General Hardware' started by bilal388, Nov 27, 2006.
  1. bilal388
    bilal388 Geek Trainee
    someone tell me wats wrong with my comp casyue i was playin my gamepad and it suddenly stopped working lsat week i have tryed everything but nothin happens i have a nexxtech 261-8302 i think the usb doesnt detect it wen the same port detects the mouse ..ii install the software again and again but it doesnt detect and the controller work becuz as soon as i turn it on teh light turns on it
  2. Willz
    Willz MiCrO$oFt $uK$ :D
    Have you tried the Gamepad in another computer? Does the Gamepad have any light on it, so when you plug it into the the computer it lights up or something?, usually you dont need to install software for Gamepads under Windows XP, thats what your running right? Windows XP?, i had drivers for mine, but that was just for the Shift button on it for Combos, it worked fine withough the drivers.
  3. bilal388
    ya i worked on a antoher comp and i have installed and reinstalled again and agian but it doesnt work
  4. Willz
    Hmmm, thats a puzzling problem, so you were playing a game one day, then it just stopped?, have you tried all your games? maybe its just with that one game, maybe disabled controller in the game options.
    Also check the Device manager to see if there is a problem with the Devie.
    Start --> Right click My Computer --> Hardware --> Device Manager
