Hey guys,
I'm having a problem with my new Graphics Card. 5 months from today I bought this brand new 256 MB DDR 5500 GeForce Graphics Card, but for some reason all the colors mess up, creating a color-fiasco in my screen when I'm playing any game (most of the times even 2D), It's impossible to play! You see, when I went to Best Buy the staff told me it wasn't going to run because of my system, then I went to Computer USA and another staff member told me it should run fine with my system. Well, I called the support hotline and I followed all of their instructions and no luck, so they told me to replace it for another one, I did but I have the same problem as before. I have an 8600 HP PC model, running on a 1.00 GHz processor with 256 MB SDR RAM and I have an NVIDIA GeForce 2 card (It runs fine). Apparently, my sytem meets all the Reqs for the card. The requirements tell me that I need 128 MB RAM (Does not specify what type), 10 MB available HD space, Microsoft Windows (I have Win XP Pro), and an Intel Pentium 3 or AMD DUron or Athlon class processor or higher (I have an AMD Athlon processor).
Can someone help me or give me a little advice on this matter?
Thank You!
BTW: I removed all the drivers of the GeForce 2 using Driver Remover, and it does not help.
Thank You!
