Hello, When i goto watch a mpg / avi on my TV, with media player 9 (others don't work) Its fine in full screen mode until the toolbar goes away, after that it goes all fuzzy, the ricker?correction setting is on max but it still does it.... i'm using the latest Nvidia drivers & BIOS...
Do you know who made the card? I'm trying to find some info on it, and knowing the manufacturer would help. Also, if you haven't, see if it gives the same problem on a different TV and try a different S-Video or RCA cable.
Thanks for the reply, its a Creative 128mb I'm using a S-Video to RCA adapter @ the moment... My system specs are: AMD XP 2000+ 512MB pc 2100 Ram MSI KT400 M/B with agp 8X I'm running windows XP SP1 And Det driver version 41.09 Thanks again
Try WMP 6.4, you can get to it through the "run" menu and type "mplayer2" without the quotes, see if it will work ok as it uses less resources. Also what resolution are you running at with tv-out on?
