Geforce6600 running temperatures
Discussion in 'Video Cards, Displays and TV Tuners' started by sbazman, Feb 6, 2006.
  1. sbazman
    sbazman Geek Trainee
    I have installed a temperature/Fan monitor in a PC with a Nvidea Geforce 6600 - PCIE graphics card. but I don't know what the optimum running temperature is to set the controller up properly. ( As there may be an overheating problem as well).
  2. Big B
    I'm not entirely sure, but I believe as long as it's below 100*C, you're fine. The default threshold temp is 127*C before the core is set to slowdown by the driver, and I'm sure nVidia has a reason for it. However, if you're getting some artifacting or freeze-ups, then it may be time to check out the cooling.
    I'd check the display properties in Windows, as it shows you what the temperature is thanks to a built-in temp probe.
