Hard Drive: 4-pin Power?
Discussion in 'Storage Devices' started by Dragonarok, Feb 8, 2009.
  1. Dragonarok
    Dragonarok Geek Trainee
    http://c1.neweggimages.com/NeweggImage/productimage/22-144-701-02.jpg
    Is the connecter to the left of the SATA connecter that isn't labeled where a 4-pin power cable can go in? If so, then I could run a Hard drive on 4-pin power and a SATA cable to the motherboard?
    It's a Western Digital Caviar SE16 WD2500KS 250GB.
  2. RHochstenbach
    RHochstenbach Administrator
    Welcome to HWF :)
    The right connector (SATA power) needs to be connected to the power supply. You need a molex-to-SATA cable to connect the 4-wire power cable to the SATA drive.
