Hard Drive Whirring-Type Sound
Discussion in 'Storage Devices' started by jherwig, Jan 20, 2007.
  1. jherwig
    jherwig Geek Trainee
    I had been experiencing problems with my old Western Digital 40 Gig Hard Drive (not sure on RPM). It made a constant humming sound and occasionally, every 10 minutes or less, it would make an extremely loud whirring-type sound that lasts about 2-3 seconds and stops.
    Also, my CPU usage is very high when doing simple tasks such as opening webpages, but the CPU spiking and the hard drive sound is not simultaneous, so I don't know if that has anything to do with the problem.
    Anyways, I decided to purchase a new WD 120 gig 7200 RPM hard drive last week and the constant humming sound is not present, but the 2-3 second whirring sound is exactly the same. I was thinking this may be a problem with my power supply, but I'm not sure.
    Can anyone help me out??
  2. Willz
    Willz MiCrO$oFt $uK$ :D
    Hi, welcome to HWF :)
    All i can think of is that the Hard Drive is on its way out if its making unusual sounds like that.
  3. jherwig
    I think I'm going to try and get some more RAM before I totally give up. I've ran a few tests on my hard drive and they don't detect anything wrong.
  4. Willz
    The ram cant be causing a whirling sound on your hard drive though, bad ram causes thngs like resets and stuff games not working properly or windows not installing sometimes or BSODs.
  5. varactor
    varactor Geek Trainee
    try monitor your hard drive with a S.M.A.R.T tool if your hardDriver supports SMART ofc.
    Search for "hard drive smart" in google and you get the tools for this in the very first few results.
    Good luck
  6. donkey42
    donkey42 plank
    what model of HDD is it ?
    here is WD download page to download data Lifeguard diagnostic tools
  7. sabashuali
    sabashuali Ani Ma'amin
    It could also be one of the fans..... try and disable the fans (not the CPU one) and see if the sound stops....
    The reason for mentioning it is that my Freezer 4 bearing is on its way to meet its maker and it sometimes makes a terrible noise....
