Hi all, I have an issue connecting my PC to my HDTV and getting HD resolution. Specs on my machine: Dell dimension xp desktop, 2.66 ghz, 1.5GB ram. RADEON 9250 PCI card, RADEON 9800 AGP Card. Running Win XP SP3. Television is a 50" Panasonic DLP. I have a VGA connection on my HD television, and I have the RADEON 9800 attached to the tv. The problem is the VGA connection doesn't seem to support any resolutions higher than 1024X768. I am wondering if there is something I can do to either get the VGA to work in a higher resolution, or if there is a PCI graphics card out there with an HDMI out on it that I should buy, and just yank the 9250 out of my machine and replace it with that. Any suggestions would be helpful. Thanks!
Hi, it will not make a difference because your tv max resolution is 1024x768. so if you want higher resolution you will have to buy a true 1080p screen.
Sorry for double post, I didn't realize I had 2 threads going. I bought a 55" LCD tv true 1080p. I hooked it up via my VGA port to the radeon 9800. It will now except 1920x1080 resolution, but it does not display the full desktop. Instead it scrolls around as I move the mouse. So, will it play a video that is 1080 p properly? I use vlc as my media player if that matters at all.
your tv max resolution is 1024x768. so if you want higher resolution you will have to buy a true 1080p screen wholesale dvds Micheal Jackson dvd Brothers and Sisters dvd South Park 1 dvd Cold Case dvd P90X dvd New Adventures Of Superman dvd MASH dvd Family Guy dvd Battlestar Galactica dvd House dvd Planet Earth dvd Disney Special dvd OSCAR dvd 007 James Bond Ultimate Collections dvd Charmed Supernatural dvd Star Trek The Motion pictures dvd X Files dvd Wholesale DVDwholesale dvdsMicheal Jackson dvdCharmedStar Trek DVDグッチ 財布グッチ バッグlv 財布ルイヴィトン バッグ
