HDD led stays on
Discussion in 'Storage Devices' started by hawkeye60, Mar 9, 2006.
  1. hawkeye60
    hawkeye60 Geek Trainee
    Just had to install new MB (Asus A8V) as old board has died.
    Although PC is working fine the led for HDD remains lit all of the time. I does flicker when there is activity. Tried switching the lead around - but then I get no led at all.
    Any suggestions please?
  2. pelvis_3
    pelvis_3 HWF Member For Life
    Hmmm, i'm not sure what could be causing this.
    What you may try is checking your IDE and/or SATA connectors are secured properly. Changing your case HDD LED or even updating your optical drives firmware.
  3. StimpE
    StimpE lol, Internet!
    It's probably because you put the HDDLED backwards on the motherboard lead.
    Ex:
    What it's supposed to be:
    You might have done this:
    Also, there could be a problem with your IDE cable, or SATA, whatever you use. Try getting different cables and see if that solves it. And I highly doubt it's a problem with the case LED itself, so I wouldn't bother replacing that, same with optical drive firmware, I personally don't see how updating it can help.
    Hope this helps~
  4. pelvis_3
    You'd be suprised :D
  5. StimpE
    I've worked on a lot of PC's to date, and I've not once had a problem with a case LED. But I suppose its possible, just unprobable.
  6. hawkeye60
    Thanks for all your suggestions. I changed the IDE cable but still the same. Then I disconnected the DVD Rom drive and success, the problem is resoved
