Help! Automatic Updates (continuous!!) not Ideal :0)
Discussion in 'General Software' started by EmmaC, Mar 24, 2009.
  1. EmmaC
    EmmaC Geek Trainee
    My Laptop started doing an automatic update whilst shutting down the other day, it got to stage 3 of 3 and 0% complete, it then stays like this for ages then changes to 93% complete before shutting down then restarting & being at the exact same point of stage 3 of 3 & 0% & moving to 93% & then restarting. It has done this I don't know how many times - I left it for an hour & it kept repeating the same process
    Does anyone know how I can move away from this update??????? If you can help please please help put me out of my misery!
    Thanks!!
  2. zeus
    zeus out of date
    Maybe download the update again.
    If this doesnt work try and delete the update file. No doubt it sits in a temp directory somewhere.
  3. EmmaC
    EmmaC Geek Trainee
    Thanks Zeus - sadly there is nothing else on screen for me to download the update again or even acess my laptop, just the updating msg.
    Do you know how I can stop the update? Or get to see another screen?
  4. zeus
    zeus out of date
    Try starting up if safe mode. Its F8, just as windows is loading up!
  5. EmmaC
    EmmaC Geek Trainee
    Unfortunately I've tried that & it didn't work
  6. RHochstenbach
    RHochstenbach Administrator
    Are you running Vista? If so, use this guide to restore your system to a date in the past, and to prevent this from happening again.
  7. EmmaC
    EmmaC Geek Trainee
    Thanks for this info, yes I do have Vista. I'll give it a try after work
  8. EmmaC
    EmmaC Geek Trainee
    I tried the above suggestion last night & managed to get my PC to start in Safe Mode but when it did it had the same error msg ....... then it shut down & restarted in a non safe mode with the original error msg, hmmmm
    Any other suggestions gents?
