Case: ___________ Make ---------------------------> Meccer Form factor--------------------> ATX ___________ Motherboard: ___________ Make --------------------------->Intel Board --------------------------->GA-945G-DS3 ____________________________ Chipset ____________________________ Northbridge ------------------>Intel 945G Southbridge -----------------> Intel ICH7 ____________________________ CPU ____________________________ Socket ------------------------->LGA 775 CPU ------------------------->Intel: Core 2 Extreme & Core 2 Duo & Pentium D & Pentium 4 FSB ---------------------------->1066 & 800 & 553MHz ____________________________ RAM ____________________________ Slots -------------------------->4 Channel ---------------------->Dual Version ----------------------->DDRII Speed ------------------------>667 & 553 & 400MHz Voltage ----------------------->1.8v Max ---------------------------->4Gb ____________________________ IO ____________________________ Features SATA 3Gb/s interface Features Gigabit LAN connection ___________ Processor: ___________ Make --------------------------->Intel Series -------------------------->E Model --------------------------->6300 Core Speed ------------------>1.86ghz Core ---------------------------->2 Name --------------------------> Intel Core2 Duo E6300 VT-------------------------------->YES FSB------------------------------>1066Mhz ___________ Memory: ___________ Make-------------------------->OCZ Channel --------------------->Dual Speed ------------------------>PC-5400 (667MHz) Timings ---------------------->4-4-4 ___________ Gafics card: ___________ Make ------------------------>Legend GPU ------------------------->70 GPU actual ---------------->7600GT VRAM------------------------>256mb Anolouge out -------------->TV (s-vidio) DVI IO------------------------------->PCI-E Memory Interface -------->128 bit Core Speed----------------->575 Mhz Core (no.) ------------------->1 RAM Clock------------------>1400ghz RAMDAC's------------------>400 MHz Architecture ---------------->Scalar Floating point interface ->64 bit Purevideo--------------------->YES SLI----------------------------->YES Driver Architecture-------->Forceware Unifide HDTV ------------------------->YES ___________ HDD('s) ___________ Make------------------------>WD IO --------------------------->IDE Cable ---------------------->Ribbon PS. This may be a problem as the mobo is sata and these are parrelel IDE any sugestions (I think a controller will sought this out) PPS. I think it also has IDE feature please check up on this Thanx in advance
Just some clarification: The motherboard model uses an Intel chipset, but the naming convention is typical of Gigabyte products (the GA- part tipped me off). One thing you might consider is getting a P965 chipset-based motherboard instead of the older 945P-based one you have listed. The P965 is a little faster and was designed with Core 2 Duo chips in mind. As far as questions go, what power supply are you pairing with this build?
That's probably not going to cut it, unfortunately. It's +12V rail probably isn't up to handling the power load that's been shifted over there. This line powers the CPU and all PCIe cards (including video cards) and any additional power connections required by the video cards. It also power SATA hard drives. You might have 10A, and you really need to look at something with about 25A. If the system powered on with that unit, I'd be shocked. A few sub £60 units that will do the job just fine: Hiper Type-M 530 £45 OCZ ModStream 520 £57 Fortron BlueStorm 500W £51
