I am building a new Machine.(Have built 5 or 6 before but when I finished I took them to the local guru and paid a hefty fee to set them up. I have pc magazine which has the latest on setting up CMOS. What I need to know is After I install windows do I then put the Motherboard disk in and go thru that or do I go into CMOS 1st set it up and then load the motherboard Diskette and set that up?
well... if you have all the nessasary disks you should just be able to load everything after win xp is installed. thats what i have done everytime i rebuilt my computer. not to hard. but make sure you get all the little connections correct when installing the mobo to the case. that should be all, in advise i could give to ya. good luck
