Help On Upgrade !!!!!!!!!!!
Discussion in 'New Build / Upgrade Advice' started by weg, Mar 8, 2008.
  1. weg
    weg Geek Trainee
    Hi everyone,i am just about to upgrade with a new GPU and more RAM,is it best if i install them seperatly or can i do them both at the same time,if it is best to do them one at a time ,which one is best to be installed first,appreciate any help on this matter...........CHEERS WEG !!!!!!!!!!:O
  2. donkey42
    donkey42 plank
    your fine to do both together, but, be very careful about choose the RAM you buy, as the speed is not that important, but the timings are, you may find it easier to just replace your existing RAM because matching existing RAM to new RAM can be v v difficult unless you want me to try & explain it, do you ?
    personally i only buy Corsair VS
  3. weg
    weg Geek Trainee
    DONKEY42,thanks for the info just installed and all is OK.........Whilst i am on line,just a quick question,now that i have installed the GPU,do i have to disable the on-board graphics,if so,how do i do this.....Cheers WEG.........
  4. donkey42
    donkey42 plank
    yes, i would, some posh motherboard may auto disable onboard grx, but, to manually disable it just enter the BIOS, by pressing (usually <Del>) and navigate to something like "Integrated Peripherals" and look around for something like "Onboard VGA" or "onboard grfx" and select disable now save and exit the BIOS (usually <F10>) and it's disabled
  5. donkey42
    donkey42 plank
    well, it looks like you've answered your own question there
    it is very important to buy a decent PSU, personally, i have an Antec TP Trio 550W (which i highly recommend) however, there is a list of decent brand PSUs in Big Bs PSU Sticky & t5heres also a list of crap PSUs
    wattage doesn't mean anything, as i've heard a decent 350W PSU can power more stuff than a crap / generic PSU
    usually if a PSU comes free with a case is generic / crap, PSUs supply power on rails, so, my PSU produced 52amps on 3 12V rails, so, you need to look at each voltage and see how many rails it supply's power on, basically, the more rails the better i think you can get a 1000W that supply's power on 4 rails, this PSU is obviously an Antec TP Quattro
