Add a new policy
Follow these steps to add a new outgoing policy.
Step 1. Choose the LAN->WAN policy list from the available policy lists.
Step 2. Click on the Add new link.
Step 3. Fill in the following values:
Name: Specifies a symbolic name for the rule. This name is used mainly as a rule
reference in log data and for easy reference in the policy list.
Position: Moves before given position.
Action: Select Allow to allow the specified service traffic to traverse the firewall. Choose
Deny to drop all traffic matching the criteria of the specified service.
Source Nets: – Specifies the sender span of IP addresses to be compared to the
received packet. Leave this blank to match everything.
Source Users/Groups: Specifies if an authenticated username is needed for this policy to
match. Either make a list of usernames, separated by a comma (,) or write Any for any
authenticated user. If it is left blank there is no need for authentication for the policy.
Destination Nets: Specifies the span of IP addresses to be compared to the destination
IP of the received packet. Leave this blank to match everything.
Destination Users/Groups: Specifies if an authenticated username is needed for this
policy to match. Either make a list of usernames, separated by a comma (,) or write Any
for any authenticated user. If it is left blank there is no need for authentication for the
policy.
Service: Either choose a predefined service from the dropdown menu or make a custom
service.
Schedule: Choose which schedule should be used for this policy to match. Choose
Always for no scheduling.
Step 4. If using Traffic shaping, fill in the required information. If not, skip this step.
Click the Apply button below to apply the changes or click Cancel to discard changes.
