i got this error message while playing in coall of duty 1.5 in GameArena servers. i get kicked by punkbuster because of this. please help, because i get kicked i can't play scrims! btw, it only happens in these servers.
yo amigo it appears that the server thinks your cheating by disabling the fog (i assume) in any case it doesnt like that your r_nv_fog_dist is enabled. in console if you type /r_nv_fog_dist 0 or go into your graphics options and set Nvidia Distance Fog to no
following newpaws I have found simillar answer on the net for this problem Load up the game In the menu system bring down the console using the ` key type: /seta r_nv_fog_dist 0 or seta r_nv_fog_dist "0" press enter Now try reconnecting, hopefully this will have corrected the issue. You may need to restart COD after this change!
i found out how to do it. i went to options->graphics->nvidia distance fog. i then disabled it then went to play in GA server. i then got kicked for not doing anything after 15 or so minutes. Thanks for your help guys.
