Without a doubt, the best way to convert a DBX file to a PST file is to use the DBX to PST Exporter. The utility also works with DBX files and can move Outlook mailbox objects without any issues. The DBX to PST Converter is a trustworthy and effective tool for converting DBX files to Outlook PST files. You can easily convert DBX files into PST file format with cc, bcc, to, from, date, time, and subject as examples of meta data. You can use a free demo device, and if you are satisfied with it, then you can buy it.
