Dear All, I was purchase a pc for home use in January, 2007, but after few days the pc does not work properly. Their are three major problem i.e. Restarting, display and Memory issues. 1. Computer does not restart proper gives three beep and shutdown. 2. Display Problem 3. Two ram jointly not supported. pc does not start. Somebody tell me that these problems is relating to motherboard, so I complaint to Intel and they want some informations that is undergiven. I give all the answer and sent my mother board and processors and processors fan to Intel. After 20 days the Intel sent my motherboard and ask me that mother board is ok and they changed the processors fan, which was faulty. But now I saw that the problem remain. Now all the same problems are remain, pc does not work properly. My details are as follows: SMPS Voltage : 220 volt , 50 hz (input) and AC 220 volt , 1.5a , 60 hz output Company : Pers RAM Company : Simmtonics (DDR 2) 533 Mhtz Size : 256MB PROCESSORS Model No : Dual Core 2.8 Ghtz (P4) PROCESSOR information as follows: Intel(M) (C)' 04 (Pentium' D) 820SL8CP MALAY 2.8 GHZ / 2M / 800 / 05 A L631B062 2L635326A1210 Dual Processing Made in Malayasia PROCESSOR FAN details as follows: a. Does the cooler fan have an Intel® hologram logo? YES b. Cooler Fan Part Number 1 : D34017- 002 c. Cooler Fan Part Number 2 : 260846 43 d. Cooler Fan Part Number 3 : FHP - 7533 ( 12UDC 0.60A ) e. Manufacturing Company : FUJIKURA Please help me in this matter. Thanking You, Manish Bhardwaj
can you tell us the BIOS manufacturer, if you don't know use PCWizard to find out, then look at this page to find out what the beep code means lets solve the boot problem first, then see what problems (if any) remain remove 1 and test the remaining RAM with Memtest86+ & then swap the RAM and test the other 1 BTW: if the RAM is incompatible with each other then just insert the largest stick Edit: did you change or add something
well at first pentium d820 cpu use 285watts when full loaded and i need to know that how much does your psu supply for usage at first days you didn't use the pc for overloading it than after a few day you start playing games, watching videos etc. right as we consider a new mobo like 945p etc. it needs 20watts (approx.) counting a stick of ddr2 takes 18watt and a hdd 25watt and a gfx and much more i think that's because of your power supply, check it out for the output power
