J Drive Problem
Discussion in 'General Hardware' started by SexiMexi9018, Nov 2, 2006.
  1. SexiMexi9018
    SexiMexi9018 Geek Trainee
    I can't remember how this happended but it happended and i have a J: Drive and i made it into another DVD drive, and i cant do anything to do, its just always up there and i need to know how to get rid of it, beucase it just there and i cant even do anything with it. so if any one knows how to remove useless dirves please tell me
  2. Karanislove
    I dont know wat that drive is but I think it could be a virtual drive created by some kind of software like Partition Magic.......I dont know exactly how to remove it but I've got an idea and may b this could help u... Just put ur windows CD into ur drive... Press enter for new installation and when it asks for chosing a drive, delete "J" drive then..
  3. Big B
    I'm confused.
    Is this a hard drive/partition or a DVD drive?
    Are you using a CD emulator?
  4. donkey42
    donkey42 plank
    if you were using a CD emulator (like Virtual CD) and you uninstalled it, it can somtimes leave a Virtual CD on your system, it wont do any harm if you can igrore it, to remove it, install the CD emulation software and remove the Virtual CD then uninstall
  5. SexiMexi9018
    well what i did was i used Alchol 120% to burn something and then somehow i copyed my DVD drive onto the drive that Alc. 120% made, dont ask me how, it was a long time ago and i dont even remember doing it all i remember is that it happended. But i put a pic in here of what my "my computer looks like so if u wanna check it out
  6. megamaced
    megamaced Geek Geek Geek!
    Alcohol 120% creates a virtual drive by default. You can drag .ISO files into it and run them as if they were actually on CD.
    To remove the virtual drive, you will need to browse the AlcoholSoft settings. There is an option to disable the virtual drive in there
