i am having trouble finding a cheap LCD display for computer, is there any that are practically telivisions so you can connect an antenna cable to it, so all i really want is a LCD telivision that will act as a really good monitor aswell, 21" would be brill! anywere to get a good one?/what should i get? (uk stores)
i think your best bet would be to go to somewhere like Curry's or Comet and look in the television section to see if there's a television with a DVI/VGA input...then if there is look on the net for a good deal/full specs
hmmm, but if it did have dvi/vga input, how would i link it to the computer? as there would have to be a special cable that has both male pins on them would there?
http://www.currys.co.uk/martprd/sto...4&category_oid=-20090&fm=null&sm=null&tm=null there's one that has a PC input, have a look at others on that site EDIT: This one is bigger 26" and its widescreen, which could be an advantage for Movies and/or games http://www.currys.co.uk/martprd/sto...8&category_oid=-20090&fm=null&sm=null&tm=null
they may provide you with a cable, or you may have to buy one, but with my LCD screen there is a cable and the connector on the screen is the opposite to the end of the cable which isnt connected to the computer, they wouldn't set it up to mess things up with connectors i dont think, with most CRT monitors the cables runs directly into the screen and you cant disconnect it, but TFT/LCD screens cables can be disconnected and have connectors like those on your video/graphics card, i'm not sure whether they would be male/felame but if the TV comes with a cable for PC connection it will have the right connectors....if not then you'd need to get an adapter but it shouldn't be a problem
lol well look around and dont worry about the connectors and cables, you can always buy adapters/connector changers
http://www.overclockers.co.uk/acatalog/Online_Catalogue_Other_Cables_153.html at the bottom are DVI and VGA cables, the connectors on the TV should correspond with those connectors on the cable. if not then: http://www.novatech.co.uk/novatech/products/a456x1y0z1p0s0n0m0 there are gender changers on there
