Lights on case
Discussion in 'Cases, Modding and Gallery' started by edijs, Dec 1, 2006.
  1. edijs
    edijs Programmer
    Hi.
    One old PC of mine got a new HDD from an old PC which, on the other hand, got fried. Now, I installed the system and everything seems fine, only that there're those 3 indicator lights on the case - green, yellow and red (see image - sorry for the MS Paint action, but had no imaging device). See, I have several PC's with the same specs and the same cases at work, but none has the yellow light shining. I don't really care about the light itself - I mean it's nice to have something besides itchy red and green - but not the easthetical factor is here the point. Anyways... I understand that the green one indicates power supply and the red one indicates HDD activity.
    Long story, short said - what does the yellow light indicate?
    Thanks!
      File size:
      2 KB
      269
  2. DavidNW
    DavidNW Big Geek
    I think the yellow light = 'Standby Mode'.
  3. Big B
    If you trace the wiring from the yellow LED, you might be able to find out what it's intent is and might be able to match it to the appropriate front-panel header.
    PC cases generally come with only 2 indicator LEDs, so the 3rd one is probably proprietary.
  4. LeeShore
    LeeShore Geek Trainee
    The yellow light is standby !! Well it is on mine !?!
