Me and a friend are looking for a case to build a nice portable frag box any links , ideas and, or suggested models? heres the mobo were gonna run unless anyone has anything thats got better reviews... http://www.newegg.com/Product/Product.asp?Item=N82E16813130529 Thanks much
http://www.newegg.com/Product/Product.asp?Item=N82E16811144161 - Just do not use the included PSU. You will thank me later.
The Antec ARIA is pretty popular, although it might be on the expensive side. max12590 is right about the power supply: don't use it if it's included in a case. Aspire isn't a brand of power supply I'd recommend either...at least if you value your investment much at all.
