Hi, I tried to import an .mpp file and I got the following error: java.class.path: eclipsito.jar;. java.home: C:\Program Files (x86)\Java\jre7 java.ext.dirs: C:\Program Files (x86)\Java\jre7\lib\ext;C:\windows\Sun\Java\lib\ext java.io.tmpdir: C:\Users\peter.danailov\AppData\Local\Temp\ java.runtime.version: 1.7.0_51-b13 java.vendor: Oracle Corporation java.vm.name: Java HotSpot(TM) Client VM java.vm.vendor: Oracle Corporation java.vm.version: 24.51-b03 os.arch: x86 os.name: Windows 7 os.version: 6.1 sun.java.command: org.bardsoftware.eclipsito.Boot ganttproject-eclipsito-config.xml -log user.country: US user.dir: C:\Program Files (x86)\GanttProject-2.6 user.home: C:\Users\peter.danailov user.language: en user.timezone: Europe/Minsk Is there a way to stop this error?
How big is your mpp file? You may try increasing the amount of memory available to Java Runtime. Unfortunately you can't do it for ganttproject.exe (which is associated with GanttProject shortcuts in Windows menus) but you can do it for ganttproject.bat which comes with ZIP distro (and with Windows distro too, AFAIR). Try replacing -Xmx512m with -Xmx1024m in ganttproject.bat and start that bat file. Also I can suggest this program Recovery Toolbox for Project https://project.recoverytoolbox.com/
