MoBo Front panel connection
Discussion in 'CPU, Motherboards and Memory' started by spike47, Jan 12, 2009.
  1. spike47
    spike47 Geek Trainee
    Hi there
    I have a problem with sorting out the front panel conectors on a imedia 5055 MoBo , it is a Gigabyte MoBo GA-8SIML ver 1.0 , but it is a version that is not on the Gigabyte site they only have ver 1.1 and above , and the Front panel conector on the MoBo is not the same .
    http://common.packardbell.com/itemnr...mbia_fpcon.gif
    Info from iMedia 5055 Manual
    inboard row
    1.HDR Blink green 2.HDR Blink yellow 3.FP BUT in 4.GND 5.FPSLP 6.GND 7.Blank 8.IR P 9.Chasis Intrusion
    outer row
    10.HD PWR 11.HAD 12.GND 13.FP Reset 14.+5V 15.IRRX 16.GND 17.IRTX 18.Chasis Intrusion
    it is a 18 pin connector , ie 2 rows of 9 pins
    Actual Leads from my front Panel
    1. HDD Led 2 pins
    2. Rest SW 2 pins
    3. Power SW 2 pins
    4. Power Led 3 pins ( centre pin blank)
    Can anyone help me as to what Leads go on where ! . ps: the numbers I have put on to help , I have put a link to the imedia front panel connections for the MoBo.
    I appologise if it all seems abvious
    cheers
  2. DaRuSsIaMaN
    DaRuSsIaMaN Geek Comrade
    hm your link gives a 404 error
  3. RHochstenbach
    RHochstenbach Administrator
    Welcome to HWF :)
    Connect each front panel plug to these pins:
    HDD LED: HD Blink GRN + and HD Blink YEL. If the HDD LED doesn't light up, then reverse the plug.
    PWR SW: FP BUT IN and GND. The direction of the plug shouldn't matter here.
    RESET: FP Reset and GND. The direction of the plug shouldn't matter.
    PWR LED: HD PWR and HDA. If the power LED doesn't light up, then reverse the plug.
