hi frindz my pc monitor display is shacking often. after some time its working properly. i'm using Samsung 17'' CRT monitor and getting power supply from stbilizer(220 V). what is the problem n how can i fix it?
Have you tried giving it its own 'kettle' plug supply? Check the VGA/DVI connections. Degause (will be in the CRT's menu) Make sure there are no magnetic fields around it. Hope one of these works, good luck
Hi, Hatarisana. In my opinion you need to increase screen refresh rate, you can do it here: right click desktop>>properties>>settings>>”advanced”>> monitor>> Screen refresh rate.
