monitor not working properly, many links
YorkBst
Geek Trainee
operating sys win7 x64
power 750 watt Antec
monitor, vp201b LCD
http://hk.viewsonic.com/en/products/productspecs.php?id=143
motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157241
new memory 16 gigs [up from 8 gigs Ripjaws, upgraded this morning]
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231486
not that it matters maybe but 250 gb primary, 500 gb secondary harddrives
video
Nvidia 560 ti w/ latest drivers
So my problem is that my monitor [might be time for an upgrade, this is not the 1st time by any means I've had problems w it] does not display any picture. I turn on my computer and it cycles through D-Sub, DVI-A, and DVI-D prompts. It settles on D-Sub but then goes dim from a green light to an orange one and displays the Error "D-Sub connection error." This morning I got my new memory, and installed that. Everything was unplugged and off and I grounded myself before touching the computer. Then I saw that my 500 gig secondary was unplugged so I replugged it with a SATA2 cable. I did nothing else! Computer was working perfectly yesterday....
I checked my cables are tight and they are and all plugged in.
I pressed some buttons on the monitor to cycle through modes, D-Sub, DVI-A, and DVI-D. They all give the no connection error. I booted up and pressed F8 like a madman but no safe mode because the monitor doesn't work.... I'm on spring break now so I'm thinking maybe it's time for a new monitor and it will come probably right before classes start. I know the VP201b is old but it's a good workhorse and i'd like to keep it living if possible.
FYI I was looking at this new monitor. Highly rated, many eggs and decent price.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236079
Would it be good for my system? I see it says DVI for imput so I think I can make that work, yes?
Please help
Thank you for reading my thread, I'm sorry for it's length
[email protected]
