what's up with these motherboards that only have 1 or 2 fan power plugs? is there any way around this lack of plugs problem (besides buying a more expensive MB)?
they also sell adapters that will convert the small 3 pin to a 4 pin molex if this helps any. http://www.google.com/products/cata...a=X&ei=RpgRTvO_JfOosALZ8IStCg&ved=0CEkQ8gIwBA
You can also get splitters for these connectors to hook up more fans. look at these: http://www.ebay.co.uk/itm/NEW-Gelid...pt=UK_Computing_Case_Fans&hash=item2c73f9f111 http://www.ebay.co.uk/itm/Computer-...-PIN-FAN-POWER-Y-SPLITTER-1-Male-to-2-Female- /251008876636?pt=UK_Computing_CablesConnectors_RL&hash=item3a714b805c Don't worry about the 4pin connector they will both work with 3pin connectors.
