Multiple temperature monitor
Discussion in 'General Software' started by Ferg, Sep 20, 2007.
  1. Ferg
    Ferg Manbearpig
    Wondering if such a program exists, probably doesn't as I can't seem to find it.
    I am wanting ONE program to tell me the temperature of my
    CPU(s) (amd x2 6000+)
    GFX card (BFG 8800gts)
    Mobo (MSI K9N Neo V3)
    The only way so far I've been able to see them all at once(ish) is to use the MSI program that came with the mobo - Horridly designed and overdone GUI (I had to press a button to switch between CPU and Mobo temp tho and with Nvidia's Ntune app running to tell me the GFX temp. Ive also tried speedfan but that still only did CPU and MOBO.
    The reason... does there need to be one ^^ ok, its a new build and I like to get an early warning if something is going wrong.
    Any thoughts?
  2. RHochstenbach
    RHochstenbach Administrator
    You could try SpeedFan. You could also enter the BIOS and go to H/W Monitor. But SpeedFan is better if you want to see the temperature at stress levels.
  3. Ferg
    Ferg Manbearpig
    I said that I'd tried speedfan, it only does my CPU and HDD's
  4. RHochstenbach
    :doh: I'm sorry, didn't see that. You could try the diagnostics program SiSoft Sandra.
  5. Ferg
    Ferg Manbearpig
  6. edijs
    edijs Programmer
    for the video card, I use ATItool.
  7. Ferg
    Ferg Manbearpig
    even for an nvidia card? :chk:
  8. edijs
    edijs Programmer
    Yeah, the author should find a more appropriate name, but it works on GeForces as well as on Radeons. I do also overclocking w/ this tool.
  9. Ferg
    Ferg Manbearpig
    Aha good to know - thanks :)
