Need Advice On My Build
Discussion in 'New Build / Upgrade Advice' started by harlequin, Sep 20, 2011.
  1. harlequin
    harlequin Geek Trainee
    So after checking out many items, many cases, and so on I decided to go for a small footprint mATX case, that is clean and can support the items I need.
    Anyway this is the build I came up with:
    Case:
    Ft03 silverstone silver
    PSU:
    Seasonic X660 Modular
    Motherboard:
    Asus Maximus IV Gene-Z
    CPU:
    i5 2500k
    GPU:
    Asus GTX 570 direct cu ii
    CPU Cooler:
    Corsair H80
    Memory:
    Corsair Vengeance 1600mhz cl8
    HDD:
    Samsung F3 1tb
    SSD:
    OCZ Vertex 3 60gb
    Price: 1500 dollars
    Consider that the Prices in my country are higher so, if bought fully in the US for example all parts its about 1000-1200.
    Questions:
    Good build? should I change something?should I replace the case fans?H80 fans?How far do you guys think I can OC my CPU?
    Thanks Alot!
    Harlequin
