Well let me get straight to the point, when I try to overclock my system fails to post and tells me to either continue to bios setting to fix it or boot with previous settings. SPECS: CPU - Intel core 2 duo E6600 P/S - 430w Ram - 3GB (1gb, 1gb, 2x512mb) Mobo - Intel D975XBX2 The weird thing is if i even try to "OC" by increasing the bus speed by one it will give a fail post. I know you have to increase voltage but I read that people can OC an E6600 to 3ghz with stock voltage. I have a really good cooling system so I'm not worried about temp neither is that a problem when OC'ing. any help would be great thanks in advance
What video card do you have? What make and model of power supply do you have? Wattage doesn't mean a whole lot.
Diamond Ati Radeon hd 3870 P/S Newegg.com - Antec earthwatts EA430 430W ATX12V v2.0 Power Supply 100 - 240 V UL, CUL, FCC, TUV, CE, CB, C-tick, CCC - Power Supplies
