Need Major Help Uk
Discussion in 'Video Cards, Displays and TV Tuners' started by Boost, Jul 29, 2006.
  1. Boost
    Boost Geek Trainee
    My graphics card seemed to be over heating because my computer kept shutting down when playing online games when the graphics would begin to bcome difficult to handle
    The graphics card was very hot so i took it apart to find the problem and the putty between the fan unit and the board has evaporated anyone know where i oculd find some more to replace at all?
    or any other suggestions would be great
    thank you
  2. Big B
    Any computer shop should sell some tubes of thermal paste. Just apply a thin layer and slap the fan on again.
  3. Boost
    Boost Geek Trainee
    thanks
    any other ideas on how to keep it kool
  4. donkey42
    donkey42 plank
    yeah, the HWF god is correct (again) but only apply a paper thin layer of thermal paste, and if you need to remove it you´ll need some Isopropel Alcohol (available from your local chemist, you may be asked to sign the poisons book, just tell them why you want it (to remove thermal paste from CPU))
