I did a search with www.pricewatch.com and I found this mobo very cheap. The main help I need is making sure that it will be compatible with my p4 2.4ghz cpu. Below is the motherboard. Thanx. http://www.pcdirect.com//product.asp?Sku=MB-007
Is your 2.4 a 2.4B or 2.4C? The reason I ask is that that motherboard only supports an FSB of 400MHz. The 2.4B has an FSB of 533MHz, while the C has it at 800MHz. Otherwise, that's probably alright. Second thing, you might want to check out that shop over at Reseller Ratings to see what kinda of reputation they have. It's cheap, but you don't want a hassle waiting for your stuff to come in.
