Need some help with hardware damage control
Discussion in 'General Hardware' started by Guitarwolf, Jun 19, 2010.
  1. Guitarwolf
    Guitarwolf Geek Trainee
    Alright my PSU fried my MB but I was lucky and the HDD is fine. I got a new MB and heres the psu -
    Newegg.com - CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
    Now I hooked everything up and actually got it to boot! HURRAY! Problem is heatsink fan isn't working. I tried hooking it into every input and no luck. It is a stock heatsink so I might as well upgrade right?
    I don't want to spend much and don't plan on overclocking. Any suggestions for a decent heatsink? I will also be scraping off the old thermal paste and applying more as I wait for it in the mail.
    Was looking at this - http://www.newegg.com/Product/Product.aspx?Item=N82E16835150086
    Here is my setup -
    e8400 core 2 duo 3ghz
    BFG 8800 GTS OC
    Other question. My vid card is hot to the touch even when just booting up and not playing any games. Does this mean its on its way out from the power surge from the psu? I will test temps once I get the heatsink and report back.
  2. Big B
    I don't know if that particular unit is rated for your CPU, so I personally wouldn't recommend it. You might have to spend a little more, and if I were going to spend money on a new heatsink, I'd probably look at Arctic Cooling, specifically, the Freezer 7 Pro Rev. 2. I've used their Freezer 7 Pro and Freezer 64, and they've been excellent units.
    I believe the 8800's run on the warm side, so I wouldn't worry yet. It is a good idea to check those temps, however.
