I did maintenence on my Pc the other day and a reformat. Cleaned the inside and removed the case fan and replaced. Over the past 3 days when switching pc on in the morning, there is no power getting to my pc, I have to unplug the power lead at the back and put it back again before I'm able to switch on. Once on, everything seems fine. Any advice most welcome please. Thanks in advance.
Sounds like it could be coincidental timing. First thing I would try is to just replace the power supply power cord. That would be cheapest and if you aren't getting a good connection could fix your issue.
