Whenever I try to play a swf document in firefox theres no sound, although the animation is fine. I've tried installing the flashplayer plugin manually for firefox and konqueror but still nothing.
Try downloading and installing the new flash player if you havn't already done so! http://www.macromedia.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash
I tried using the rpm, and also doing a manual install to the plugins directory but still no sound. I've looked around and some people say this is a problem with KDE.
I dunno about that, I'm running KDE and Flash works fine for me. Never had any problems with sound in Flash. Could you open Firefox and type Code: about:plugins in the address bar, then post the results? If they're long, you might want to save/zip the file before posting it. Thanks, -AT
Its ok now for some reason. My problems get fixed a lot but I don't know how. Annoying. Anyway maybe just the plugin wasn't working. I can now view: www.endofworld.net in Linux.
