No Sound
Discussion in 'Sound Cards and Speakers' started by dnham, Aug 29, 2006.
  1. dnham
    dnham Geek Trainee
    My sound has completely disappeared for about 3 days now and I don't know why. I checked the device manager and everything is in order...
    Please help! Thanks =)
  2. Karanislove
    Which sound you are using........
    1. Onboard
    2. PCI
    Also would like to confirm couple of more things........
    1. Did you ckeck in your sound that there is no click on the Mute box either on Wav or Volume?
    2. Check your speaker wires, are they properly inserted.
    3. Check your Speaker power.
    4. As you have already listed that you have checked the device manager, so I assume that there is no yellow sign in there.
  3. dnham
    dnham Geek Trainee
    Hi,
    I can't even check if it's mute or the power is on or off, because there is no "sound device installed" according to my computer. All the cables and such are plugged in too.
    I believe it's PCI...? How can I check?
  4. Karanislove
  5. dnham
    dnham Geek Trainee
    Hi,
    I used this program called Everest, and it tells me I have PCI.
    Device Description Type
    C-Media CMI8738 Audio Chip PCI
    Creative SB Live! Sound Card PCI
    Is this right? I hope this helps.
  6. Karanislove
    TO download drivers from C Media website......... [link=http://www.cmedia.com.tw/?q=en/PCI/CMI8738]Click here[/link]
    Also make sure that you have disabled the onboard sound device. You can do it through bios.
  7. dnham
    dnham Geek Trainee
    Hi,
    I fixed it!!! Thank you for your help =)
