No Sound
Discussion in 'Sound Cards and Speakers' started by shoeman64, Mar 2, 2007.
  1. shoeman64
    shoeman64 Geek Trainee
    There is a sound card on my PC but no sound. I think it is Realtek AC'97 Audio. I have XP
  2. RHochstenbach
    RHochstenbach Administrator
    The drivers for that device are located here.
  3. shoeman64
    Have downloaded driver but still no sound from speakers
  4. RHochstenbach
    This might sound wierd, but are the speakers connected to the correct output of the soundcard? And is the sound output not muted?
  5. shoeman64
    have checked all that
  6. RHochstenbach
    Richt-click on the My Computer icon. Click on Properties. Then go to the Tab Hardware, and click on Device Manager. Are there any exclamation marks there? Also, check in Volume Control if the option WAVE is not muted and the slider is completely to the top.
  7. eranga262154
    eranga262154 Geek Trainee
    Most of the time volume option can be muted someware. Check all the posibilities, if your speakers not working.
  8. Karanislove
    [ot]
    Easy way...Right Click MyComputer > Manage > Device Manager ;)
    [/ot]
  9. eranga262154
    Shortcuts always reliable.....
  10. shoeman64
    Gone into Device manager and then Other Devices= Multimeda Audio Controller
    Message to say "driver not installed" tried to update but pc cannot find driver.
    Then there is Video Controller. There are yellow question marks at these 3
  11. Karanislove
    You have to download those drivers first from the link provided RH in the second reply...And then uninstall those components in yellow marks. Restart your computer, then your computer will detect the new hardware and will ask u to install the drivers for it. Go through that wizard and specify that location where u downloaded those drivers....
  12. eranga262154
    Without restart and all the stuff can we update the drivers. Is it make sense.
  13. shoeman64
    Have done everything as suggested but still no joy. About ready to give up:(
  14. Karanislove
    First make sure which sound card do you have so that you can grab the exact drivers required for it. Second thing, try and change the PCI slot...
  15. eranga262154
