no sound?
Discussion in 'Sound Cards and Speakers' started by rathead, Dec 13, 2005.
  1. rathead
    rathead Geek Trainee
    rite brand new pc here lads :D get in !!! woohooo only problem is i have no sound what so ever.
    rite i got a chip inetergrated by realtek ALC850 ( 7.1 ch H/W audio )
    please reply i need serious help im a noob on pc's
  2. megamaced
    megamaced Geek Geek Geek!
    Have you installed drivers for you sound card?
    If not, follow this link:
    http://www.realtek.com.tw/downloads/downloads.aspx
    You should be able to find the appropriate drivers from there.
    If you have installed drivers, have you turned all of the volume switches up? It's a simple mistake. Make sure 'Master' 'Wave' and 'CD audio' are all turned up.
    If you have tried all of the above, is your device showing any kind of error in device manager?
