Hey! Today I got my new computer's last component and installed all up but I didn't get a fast computer... Slower than my 5 years old computer? I have installed all the drivers and everything but the responce time seems to be very low. I am also getting "xxxxx not responding." from time to time. The harddrive is approx 10 years old... Here are the specs: (+5 MINUTES to open dxdiag btw) Code: ------------------ System Information ------------------ Time of this report: 2/14/2009, 09:56:57 Machine name: JONI-SNSC6YGUSR Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-xxxx) Language: Finnish (Regional Setting: Finnish) System Manufacturer: System manufacturer System Model: System Product Name BIOS: BIOS Date: 09/16/08 11:01:13 Ver: 08.00.14 Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 5000+, MMX, 3DNow (2 CPUs), ~2.6GHz Memory: 1920MB RAM Page File: 422MB used, 3390MB available Windows Dir: C:\WINDOWS DirectX Version: DirectX 9.0c (4.09.0000.0904) DX Setup Parameters: Not found DxDiag Version: 5.03.2600.2180 32bit Unicode ------------ DxDiag Notes ------------ DirectX Files Tab: No problems found. Display Tab 1: No problems found. Sound Tab 1: No problems found. Sound Tab 2: No problems found. Music Tab: No problems found. Input Tab: No problems found. Network Tab: No problems found. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (n/a) DirectDraw: 0/4 (retail) DirectInput: 0/5 (n/a) DirectMusic: 0/5 (n/a) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) --------------- Display Devices --------------- Card name: NVIDIA GeForce 8200 Manufacturer: NVIDIA Chip type: GeForce 8200 DAC type: Integrated RAMDAC Device Key: Enum\PCI\VEN_10DE&DEV_0849&SUBSYS_82F21043&REV_A2 Display Memory: 512.0 MB Current Mode: 1280 x 1024 (32 bit) (75Hz) Monitor: Plug and Play -näyttö Monitor Max Res: 1600,1200 Driver Name: nv4_disp.dll Driver Version: 6.14.0011.7521 (English) DDI Version: 9 (or higher) Driver Attributes: Final Retail Driver Date/Size: 5/22/2008 21:19:00, 6109824 bytes WHQL Logo'd: n/a WHQL Date Stamp: n/a VDD: - Mini VDD: nv4_mini.sys Mini VDD Date: 5/22/2008 21:19:00, 6557664 bytes Device Identifier: {D7B71E3E-4B09-11CF-926E-F9A203C2CB35} Vendor ID: 0x10DE Device ID: 0x0849 SubSys ID: 0x82F21043 Revision ID: 0x00A2 Revision ID: 0x00A2 Video Accel: ModeMPEG2_C ModeMPEG2_D Deinterlace Caps: {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch Registry: OK DDraw Status: Enabled D3D Status: Enabled AGP Status: Enabled DDraw Test Result: Not run D3D7 Test Result: Not run D3D8 Test Result: Not run D3D9 Test Result: Not run ------------- Sound Devices ------------- Description: HD Audio rear output Default Sound Playback: Yes Default Voice Playback: Yes Hardware ID: HDAUDIO\FUNC_01&VEN_1106&DEV_E721&SUBSYS_10438345&REV_1001 Manufacturer ID: 1 Product ID: 100 Type: WDM Driver Name: viahduaa.sys Driver Version: 6.00.0001.1510 (English) Driver Attributes: Final Retail WHQL Logo'd: n/a Date and Size: 7/25/2008 14:09:24, 845184 bytes Other Files: Driver Provider: VIA Technologies, Inc. HW Accel Level: Full Cap Flags: 0x0 Min/Max Sample Rate: 0, 0 Static/Strm HW Mix Bufs: 0, 0 Static/Strm HW 3D Bufs: 0, 0 HW Memory: 0 Voice Management: No EAX(tm) 2.0 Listen/Src: No, No I3DL2(tm) Listen/Src: No, No Sensaura(tm) ZoomFX(tm): No Registry: OK Sound Test Result: Not run Description: NVIDIA High Definition Audio Wave Default Sound Playback: No Default Voice Playback: No Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0002&SUBSYS_10DE0101&REV_1000 Manufacturer ID: 1 Product ID: 100 Type: WDM Driver Name: nvhda32.sys Driver Version: 1.00.0000.0017 (English) Driver Attributes: Final Retail WHQL Logo'd: n/a Date and Size: 1/11/2008 07:02:04, 31392 bytes Other Files: Driver Provider: NVIDIA Corporation HW Accel Level: Full Cap Flags: 0x0 Min/Max Sample Rate: 0, 0 Static/Strm HW Mix Bufs: 0, 0 Static/Strm HW 3D Bufs: 0, 0 HW Memory: 0 Voice Management: No EAX(tm) 2.0 Listen/Src: No, No I3DL2(tm) Listen/Src: No, No Sensaura(tm) ZoomFX(tm): No Registry: OK Sound Test Result: Not run --------------------- Sound Capture Devices --------------------- Description: HD Audio front mic Default Sound Capture: Yes Default Voice Capture: Yes Driver Name: viahduaa.sys Driver Version: 6.00.0001.1510 (English) Driver Attributes: Final Retail Date and Size: 7/25/2008 14:09:24, 845184 bytes Cap Flags: 0x0 Format Flags: 0x0 Description: HD Audio rear input Default Sound Capture: No Default Voice Capture: No Driver Name: viahduaa.sys Driver Version: 6.00.0001.1510 (English) Driver Attributes: Final Retail Date and Size: 7/25/2008 14:09:24, 845184 bytes Cap Flags: 0x0 Format Flags: 0x0 ----------- DirectMusic ----------- DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS DLS Version: 1.00.0016.0002 Acceleration: n/a Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port NVIDIA High Definition Audio Wave, Software (Kernel Mode), Output, DLS, Internal Microsoft MIDI-kartoitin [Emuloitu], Hardware (Not Kernel Mode), Output, No DLS, Internal Microsoft GS Wavetable SW Synth [Emuloitu], Hardware (Not Kernel Mode), Output, No DLS, Internal Registry: OK Test Result: Not run ------------------- DirectInput Devices ------------------- Device Name: Hiiri Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Device Name: Näppäimistö Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Device Name: USB Receiver Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x046D, 0xC517 FF Driver: n/a Device Name: USB Receiver Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x046D, 0xC517 FF Driver: n/a Device Name: USB Receiver Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x046D, 0xC517 FF Driver: n/a Device Name: USB Receiver Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x046D, 0xC517 FF Driver: n/a Poll w/ Interrupt: No Registry: OK ----------- USB Devices ----------- + USB Root Hub | Vendor/Product ID: 0x10DE, 0x077B | Matching Device ID: usb\root_hub | Service: usbhub | Driver: usbhub.sys, 8/3/2004 23:08:44, 57600 bytes | Driver: usbd.sys, 10/9/2001 14:00:00, 4736 bytes ---------------- Gameport Devices ---------------- ------------ PS/2 Devices ------------ + HID Keyboard Device | Vendor/Product ID: 0x046D, 0xC517 | Matching Device ID: hid_device_system_keyboard | Service: kbdhid | Driver: kbdhid.sys, 9/14/2004 16:07:46, 14848 bytes | Driver: kbdclass.sys, 9/14/2004 16:07:46, 24576 bytes | + Terminal Server Keyboard Driver | Matching Device ID: root\rdp_kbd | Upper Filters: kbdclass | Service: TermDD | Driver: termdd.sys, 9/14/2004 16:12:18, 40840 bytes | Driver: kbdclass.sys, 9/14/2004 16:07:46, 24576 bytes | + HID-yhteensopiva hiiri | Vendor/Product ID: 0x046D, 0xC517 | Matching Device ID: hid_device_system_mouse | Service: mouhid | Driver: mouclass.sys, 9/14/2004 16:06:10, 23040 bytes | Driver: mouhid.sys, 10/5/2001 15:59:32, 12160 bytes | + Terminal Server Mouse Driver | Matching Device ID: root\rdp_mou | Upper Filters: mouclass | Service: TermDD | Driver: termdd.sys, 9/14/2004 16:12:18, 40840 bytes | Driver: mouclass.sys, 9/14/2004 16:06:10, 23040 bytes ---------------------------- DirectPlay Service Providers ---------------------------- DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180) DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180) DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180) DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180) Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180) IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180) Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180) Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180) DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run DirectPlay Test Result: Not run Registry: OK ------------------- DirectPlay Adapters ------------------- DirectPlay8 Serial Service Provider: COM1 DirectPlay8 TCP/IP Service Provider: Lähiverkkoyhteys 2 - IPv4 - ----------------------- DirectPlay Voice Codecs ----------------------- Voxware VR12 1,4 kbps Voxware SC06 6,4 kbps Voxware SC03 3,2 kbps MS-PCM 64 kbps MS-ADPCM 32.8 kbps Microsoft GSM 6.10 13 kbps TrueSpeech(TM) 8.6 kbps ------------------------- DirectPlay Lobbyable Apps ------------------------- ------------------------ Disk & DVD/CD-ROM Drives ------------------------ Drive: C: Free Space: 20.9 GB Total Space: 38.2 GB File System: NTFS Model: SAMSUNG SV4003H Drive: D: Model: HL-DT-ST DVDRAM GSA-4160B Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (Finnish), 8/3/2004 22:59:54, 49536 bytes
At first thought, I'd point the finger at your hard drive! What hard drive does 5 year old computer have?
Aye especially if you have that sort of a page file of that size on a drive that old you'll be having problems. I dont think it is 10 years old however, you'd have been lucky to have a 2gig let alone a 40 (quickly works out how old he was 10 years ago) yeah i'm sure i was pimping a p90 with a 500 mb hard drive then.
